Dish 811 Remote with SONY AV Receiver STR DE897 | SatelliteGuys.US
PS8128
8
Does anyone know if there is a way to use the 811 remote with the Sony 897 receiver (at least for Volume). I have tried the published codes in the 811 manual and also tried the "Power Search" routine without success. Dish does not guarantee the remote will work with all receivers, but why would a new Sony receiver be so much different than the older ones?
I have a sony 695, and had to change my sony remote code setting to 1 on the receiver(the default is 2). You also have to change the remote code on the sony remote itself as well. Once you do this, the code listed in the 811 manual should work.
Thanks. It worked perfect. Saved me from that multiple remote dilema!!! Too bad Sony doesn't address this in the manual.
NBR - New Episodes vs Dish Pass
I cancelled my HD package today
