DISH and 3rd Party Moca adapter | SatelliteGuys.US
bandF
Boston MA
Does anyone know if I had a Moca Adapter that supported Band F would be compatible with the Dish network and the Hopper Internet Connector? Or does Dish prevent non Dish products from their network?
I would bet real money that dish equipment can't talk to other moca devices.
That would require encryption/decryption. Dish and D* moca adapters aren't compatible simply because they communicate on different frequencies. Moca standard only had 2 frequency ranges so if you have an adorable on the same range it "should" work.
Issues Surrounding CUI Update
Mast clamp question
