Dish Anywhere pixelating | SatelliteGuys.US
CubsWin
1,028
244
Bourbonnais, IL
Has anyone else has issues with Dish Anywhere lately? I have tried it a few times over the past couple weeks and the video is sporadically pixelating for no apparent reason. My connection is strong and everything worked fine in the past. Is there anything I can do to try to resolve it it is this yet another software issue?
Pixelation usually means that the bandwidth is low either at the receiving end (down) or the transmitting end (up). You need to measure the speed of each end.
I'm getting about 180 Mbps down / 24 up on my phone. My Hopper 3 is wired and should get that same speed or better. Bandwidth certainly isn't an issue for me.
Same here. Matt at dish says this is a known issue which will be corrected shortly. Thanks Matt.
Wireless Joey Troubles
Moca and pixelation problems
