Stiff. Coming out of access hole.
Their onsite Netflix guy huh???
will the 4K Joey upconvert the 1080i signal to 4K?
Well if you can set the resolution to 4k, then it should upconvert everything to 4k resolution. Just like if you set the hd receiver to 1080i,it does everything in 1080i. I still don't think that they have enabled native resolution support yet on any receiver.Good question I will ask today.
Limited time offer
