Dish fell over | SatelliteGuys.US
Dish fell over
Ramy
The Star Wars Collector Podcast
30,931
529
Here
My dish broke at the base due to rust and fell over. It was really windy here today. I got a new pole and put it in not knowing the diameter was too big. Ugh. Now I have to find an adapter.
Sent from my SM-N900V using Tapatalk
hmm i'm seeing rust at the bottom of the dish mount, probably nothing since it's been up there for 4 years.
At least I hope is nothing.
It had only been up for 3 years. I have never had that happen before.
Sounds like it had an open top but plugged bottom causing water to get trapped.
Ramy, you need a 1 7/8" to 2" OD ...
It sounds like its too late and you already installed it ... did you get a Fence post ?
I think they run 2 3/8th or there abouts.
That said, there are a variety of fence post sizes available ... I went in and asked about a post the size I needed and they supplied it.
I don't see a picture posted. Was this a pole mount or regular Directv mast? You can use a muffler pipe in a 2" size.
Never thought of asking a muffler shop for 2" pipe. That is a hard size to find. I seen pole adapters on ebay for 2" slimline for $15-20.
Don't use the adapters. You will be using a base that isn't strong enough to properly support a Slimline.
There are more than one type of adapter. One would go over a different sized pole (perhaps a larger easier to find pole) while another would go on other porch railings. The one I was referring to was the pole adapter.
If you are using an adapter to change a 1 5/8" mast to a 2" one, you will be using a base that's too small.
$17.99 for $4 worth of parts! Such a deal!! How are you going to slip that over a pipe whose od is at least 1/4" larger? You may never get it plumb. In the words of Mike Holmes, do it right, do it the first time. Get the proper mast and avoid the very likely problems you will encounter.
I agree that a pole is better than a pole adapter but the pole size is very hard to find in many areas so that would be some people's only solution. Someone may have to get a larger pole for this solution then put the adapter on it.
DirecTV's Super-Secret Lawsuit Against Al Jazeera Revealed (Exclusive)
My Mistake. It Only Cost Me $480:(
