Dish has trouble moving west | SatelliteGuys.US
Martyn
642
283
Annandale, VA
Hey folks,
So, my ku-band dish is having trouble moving west. From the receiver on the way to the dish, the cable runs through a 22kHz switch and a little bit of flattened coax so that it can exit the window while the window remains closed. This was never a problem until recently and I assumed the motor was just getting old.
Sometimes it helped to switch to a horizontally polarized channel to drive the dish - the voltage is higher, right?
Today I decided to see if I could move it and came across something interesting. When I told the dish to go to reference, it scooted west with no problem. Once there, as I clicked through satellites, it moved east with no problem. But if I wanted to return to a satellite I had passed, it refused to move west. In the satellite setup menu, hitting west resulted in no movement .... but telling it to return to zero sent it off west again.
I had assumed it was perhaps low current or a problem with the motor, but now I'm wondering if something else might be to blame. Is there anything fundamentally different about the signal it gets to return to reference versus move to a satellite? Why would it move for one and not the other?
Receiver is a MicroHD, motor is an SG6100. It's set to move with USALS and I've doubled checked by location is correct in the USALS menu. Dish limits are also set to off.
"a little bit of flattened coax so it can exit the window"?
What does that mean? Coax that YOU flattened, or one of the special flattened coax jumpers you can buy specifically for this purpose? Flattened coax can be trouble, from notching out specific frequencies, to causing actual FIRES. Either way, I'd suspect that first, and I'd temp bypass it and connect to your motor with a new piece of coax, and see if the problem goes away.
There is some nice flat wires I bought some while nice compared rad shack ones. Talk to wallyhts about the flat wires he sells. Another thing depends upon what your window goes up or rolls out. They have panel that you can stick in the window that goes up that will let you run a wire through ham guys need your input on this item. I live in apartment so I have to use flat wires.
Yeah I have ran into that flat coax going bad on several occasions, don't hurt to bypass it to make sure.
Ecoda 22khz frozen?
sheldon cooper
