dish hd & numbered channels | SatelliteGuys.US
varcieri
101
Sorry if this is the wrong place for this question - but why does Dish have so many channel numbers for the same programs on their hd packages? Are they all the same or are they different as far as quality & sound?:confused:
All those channel numbers map back to the same signal on the satellite. No difference between them, because they're all really the same signal.
So what's the point? To think you have more channels than you really do? Now I'm REALLY confused...
The mapping allows some to get their HD channels mapped over the SD number they are used to.
It also allows different packages to get blocks of channels with different permissions.
The map down can be turned off but the package blocks are red on all channels if unsubscribed.
AFAIK,
-Ken
Dish 322 Local Channel Info Missing From Guide
Using 2 Hard Drives on the 622
