DISH HD SIGNAL LOSS | SatelliteGuys.US
DISH HD SIGNAL LOSS
ALLTHINGS
37
I have 119 and 61.5 installed. I am running 3 DP311s from one DP34 switch and one DISHVIP 722 from the other DP34. I have several connectors, and the signal on 61.5 is being deteriorated from one DP34 to the other, on to the VIP722. The DP311s are working fine. Any thoughts would be appreciated. Should I use 3GHZ connectors? or signal amplifiers? I am not getting much HD on the VIP722.
It sounds to me like your 61.5 wing dish may need checked out. Possibly peaked and/or moved (line of site issue comes to mind). What sort of signals are you getting on the 61.5? Also, why aren't you using the 110?
"Turbocharged" 622 now acting up
Storing Timer settings on EHD vs. 2 way remote
