dish help with 522 | SatelliteGuys.US
dish help with 522
j5races
119
Hi all,
I have a dish 500 with dishpro. it has a single lnb for 110 and a single for 119. I need to hook up a 522 to it, but i only have a single feed for each sat and no way to combine and split the signal to get two feed with boths sat on them. What parts do i need to make this system right?? thanks in advance.
PS right now i just hooked up one feed off the 110 to the 522 and it has only a three day EPG and nothing on sat 2 (obviously).
thanks again Jon
DP34 would probably be the best way to go. 110 on input 1 and 119 on input 2 (I may have those reversed) then you have 4 outputs.... 2 of which go to the 522 and if you want to ad recievers in the future you have 2 more feeds
Shadow's solution is good. Alternatively, replace the existing LNBFs with a DP Quad, and sell the old ones - it's probably a toss-up as to final cost.
Shadow: I like 119 on port 1 of switches, and 110 on port 2. ;)
I knew I was backward..
Lets go ahead and get the ball rolling here...
Did my switch or my lnb fail?
