DISH Hopper Duo Timers | SatelliteGuys.US
rodder
2,351
105
Adairsville,Ga 30103
Anyone else having problems with timers i can set a timer then go back and look at it and it has changed days and some times time
Okay, I just tried it, and it works properly. When I was having trouble setting manual timers on the Wally, I found out that it helps to scroll down to the bottom of the list of timer settings and work your way up in reverse order. In other words, the channel number is the last thing I set, even though that setting is at the top of the list.
Another External Hard Drive Question
Hopper 2 Hopper trick play. Fix in what year?
