dish hopper - photo share app | SatelliteGuys.US
elknose
3
United States
any one used the hopper photo share app. Cant get it to work.
I have created public photos using Picaso Web.
Using the Hopper app I try and create a new user id using e-mail .. does not work.
tried locating my Picaso Web ID .. but all I found was a URL which was way to long.
Just curious if anyone else has tried this app.
Not sure I am using the correct login info. the Hopper app says to create a new user using my e-mail or Picaso Web ID.
e-mail did not work so I searched for my Picaso Web ID which seems to be a URL adrs. What user ID did you use ?
checked Google+ and found a 21 digit # which is part of the URL, also checked Picaso Web Albums, it is the same #.
Tried that number using the Hopper App ... no luck. contavted Dish tech support ... was advised there having issues
and to try again - 3-4 days from now... Thanks for responding to my post.
Two suggestions...
Make the blue-button menu show two rows. In combination with folders, i.e. Music, Games, etc it's doable. Second, make it a smart list that shows *our* more frequently accessed apps and a "More..." button for the rest.
Sent from my SCH-I535 using Tapatalk 4 Beta
DISH's response to the Co fires vs Direct's
help
