Dish install with Antenna | SatelliteGuys.US
malligood
27
I have a a 625 DVR , off of the second tuner I am going to be replacing my TV with an HD set that has built in HD tuner so I want to be able to get my OTA HD and my SD dish , do I use a diplexor to combine the signals, a switch box or what?
Thanks,
Mack
In this case a diplexer will not work, if the ant. is going straight to the second TV you will need an a/b switch box.
Thanks, ok so I looked at a MANT510 Phillips Antenna , it has an A/B switch builtin, would that work?
Yeah that will work. Are you right inside or close to a big city?
About 35 miles, I currently get good OTA with a Silver Sensor using my 622 HD tuner , so I hope I will be able to do the same with the MANT510 in my sunroom.
VIP 722 w/Verizon MI424WR Router
Activate without install?
