Dish Install | SatelliteGuys.US
Dish Install
MB33
9
Hi,
I have two TVs connected to OTA locals, one on each floor of the house. When I get the Dish Network installed how will the cabling work? Will I get only one dual receiver then need a few spliters? Wondering if there will be any extra costs to make it all work with the dual as there will be no extra equipment costs (from what I can tell on their website). Thanks in advance for the info.
Thanks. So the cable runs from the dish to the tuner then from the tuner to the two TVs? If so, how would the OTA cable factor in?
Installer would probably use those cables if they will work. Depends on what you have and how the house is laid out. The installer should go over that with you when they get there.
622 guide data w/o locals
Cbs Hd
