DISH Installation - Inside House Connections | SatelliteGuys.US
onionscd
6
upstate NY
How much indoor installation will DISH do? I want to run two connections from my basement: one just up to my C-BAND connections in my ground floor living room, a second from the basement straight up to a room addition which has no walls yet, then splitting the signal, one in a new room, the other into my master bedroom, running up the wall, through my attic, then through the bedroom ceiling.
Will they do that? If not, how much will they do and what do I have to do myself?
They should run 1 line to each tv on the workorder. How he is going to do it should be discussed before he starts any work. Anything beyond the workorder is open to negotiation. If you are willing to help pull cable, more will get done. The more prep work you have done, the better. (holes drilled where you want them, fish lines in the walls, etc.)
Any software/codec to read data on USB HDD?
Replacement Receiver Quality Control Problems?
