Dish IR Remote codes for Sony STRDE897 Home Theater Receiver | SatelliteGuys.US
handymantoo
SatelliteGuys Guru
138
northeast
I've tried all the codes Dish lists but none of them work. Thought possibly someone has the same receiver. As a last resort I can try a scan but that's a long drawn out process.
did you also put in the "1" or "2" before the code? i had to do that when i had to program my amp to my remote... i forgot which one it is but im sure someone here will post which one it is shortly :)
Did a Google search and it referenced an old Satellite Guy forum thread which indicated the Sony receiver has a mode setting which must be made to allow other IR remotes. Sony default is AV2 must be set to AV1. Now works with code 730. Thanks for your help.
My install story......
minimum 1 joey per hopper
