Dish limits | SatelliteGuys.US
Dish limits
uncledoc
2
Queens New York
I have a old Houston Tracker V111 and i was trying to use it to move my Jack but it is lock on both limits and i can't remember how to erase that memory..can any one help me
Thanks in Advance
Linley
Found this on the web. Hope it helps!
"Press 63 to access the x-tra features of the HTS VIII. Then select
#5 (installation) . The master password is 2226903 if an old forgotton
password had been entered earlier. Now select # 5 (change memory). Then
you will see selections 2 and 3 for setting new E and W limits. To
delete a satellite instead of #5 (change memory) select #6 (erase
memory)."
Welcome to the site uncledoc!!!
Come by more often tons of guys with tons of knowledge on here to help!!
Good Compression Tool and Stripper
SYNOQ SR1: new FTA receiver from DMS International
