dish meg-4 | SatelliteGuys.US
dish meg-4
so this receiver have input for over air antenna to get local channels?
Possibly, possibly not. The 6000 had a user-installable ATSC tuner port. You had to buy it separately and install it yourself in the early days. But later, I think after Dish came out with the 811 they started sending out refurbed 6000's with the ATSC tuners installed, IIRC. I may be completely wrong about that however. What you need to do is look on the back of the unit and on the left hand side you should see the tuner. If it has no tuner, there will be a small metal plate covering a hole where the tuner would go.
Oh yeah, forgot about that part. Haven't used a 6000 for over four years or so.
Sputtering audio on HD channels?
just moved but they didnt get rid of my local nbc
