Dish motor with dual LNB | SatelliteGuys.US
comfortably_numb
20,702
32,162
Kansas City
Received my Stab HH90 motor from raydio the other day. The dish I'm consider using it on currently has an SL2-PLL dual LNB. Is it possible to use this LNB with the motor such that both receivers (Edision OS MIO 4K and Amiko HD.265) can both move the motor independently of each other?
NO. One has to be the 'mover', and the other will be a slave to that. IE: it can only see the channels on whatever sat it's aimed at. Bonus though with the 2 output lnbf, it can see both H and V channels.
Reactions: comfortably_numb
Wouldn't a single LNB also see both H&V polarities? Now I'm confused!
Sure, but only for the "master" receiver. The slave receiver could only see whatever polarity that the master is tuned to at the time, either H or V. A dual output lnb though, is like having TWO complete single lnbs up there, and each one is separately controlled by the receiver it's hooked to.
Gotcha. That was my expectation, just wasn't sure about the ability to control the motor from only one or both receivers.
Happy Fiftieth pacificrim
Prime Focus Dual KU LNBF???
