Dish Motor | SatelliteGuys.US
Dish Motor
bincitybandit
76
I have a ku band FTA system. It is currently stationary, but I would like to motorize it if possible. The problem is that I use a 1.2m Primestar Dish, and I would like to keep using it if possible. I am told the larger the better, right. Is there a way that I can motorize this dish? I found a Pansat PM900S motor on ebay that says it will accomodate up to a 1.4m aluminum dish. Will this work? I assume some retrofitting maybe required. I use a Fortec Star Lifetime Ultra so I should be USALS capable, correct? Thanks for any help.
Add lnbs to ai5 and g10r??????
I have a problem about cool sat 4000 pro?
