dish mount adopter | SatelliteGuys.US
dish mount adopter
jerryd
110
Central Wisconsin
DOes anyone know if there is a dish mount that bolts on an existing dish frame to add a second dish without having ti mount to roof of house,
Thanks for any help you can give me'
jerryd
You could also use U-bolts to clamp a second mast just above the base of the original so they form a giant U. Depending on the size of the dishes you may need support struts to stabilize it
Is alacart even feasable?
options?
