Dish Network 500 to Bell Expressvu 6120 | SatelliteGuys.US
buckspaul
I currently have 2 Dish Network 500 dishes on my roof here in Pennsylvania for locals and HDTV i seriously want to switch to Bell Expressvu's far superior HDTV progamming and totally more diverse Canadian progamming via the 6120 HDTV system from BEV, i used to have Bellexpressu a few years ago so i know how to get programming and euipment. Tech related question, can I repoint one 18' Dish Network 500 with dual LNBF to BEV satellites to receive the two satellites on BEV? is this a simple procedure or do i need to purchase 20" dish with the 6120 system and replace on the esisting tripod? :confused:
well...sort of :)
The Dish500 will work, but you need a Twin (which has one giant "eye" instead of a small one)
a dual will not work
The 6120 system includes a 20" dish with it, and two dual lnb's and a SW-21 at no additional cost (shipping is about $50CAN more though).
dish network to BEV
btw, if your dish says 500 on it, it is already a 20" dish. The 18" dishes have 300 on them.
thanks Derwin0
I do have the dish 500 logo on both dishes currently and it looks like i have everthing i need installed already?, just checked the switch set up on my dish network it displays the following information:
Switch; DP-21 LNB: Twin 2 (1) for echostar 119 and 110
Input: 1 1 2
Satellite: 119 110 61.5
Polarity: All All All
Device: Twin Twin Dual
Im thinking i will just remove the 61.5 dish and disconnect it, will realign dish one nimiq satellites
