Dish Network 625 Ghost program | SatelliteGuys.US
On another thread someone suggest using the application, 'Ghost' to transfer a recording from one 625 to another. If this is what you mean, Ghost is a program that can copy data from one hard drive to another. Using it will require you to remove the covers from both 625s, remove the hard drive and install them in a PC.
If you are not familiar with this or the technciques of cloning one drive from another, you should probably stay away from it.
Legacy receivers on DishPro Plus
Dish Upgrade
