Will a Dishnetwork 500 dish with it's LNBs work with the Directv Sats? ie can I just repoint it and use a Directv R15 receiver? I understand that it might only be able to get one Sat... like 101 which has most of the stuff...
thanks, OB
orrenB,
Report back if it works. I never tried this.
Another hint; as you enter the zip code of the new location into your DTV reciever to tune the dish, know that the azmuth( compass direction ) shown is to the 110 satellite. You will have to adjust east /left to hit the 101.There may also be some compass deviation so it may not seem to be on the line you use.
The elevation should be adjusted per screen instructions. I know the el to DISH products is lower that the DTV sats.
Make sure the mast is "plumb" before you tune.
Good luck,
Joe
Limited time offer
