Dish Network + extra channel from IntelSat - equipment question | SatelliteGuys.US
cybersonic
30
Hi,
here's a complete newbie question...
I have been receiving an international channel through Dish Network for a while now, and have been quite happy with that. However,starting 1/1/05 that channel is now broadcast for free through the IntelSat satellite. I wasn't going to bother, but now Dish Network has decided to stop broadcasting this channel on 3/31/05 because everyone can get it for free.
So, I need to get extra equipment to get this channel in the future. I know next to nothing about receivers/antennas/dishes/etc. so I'm desperately looking for some help here... :confused:
I presume I can't use my Dish receiver for this (I currently have a model 4900 receiver, with 2 dishes)? I want to keep using Dish Network for my other channels, so I'm wondering what other equipment I need to get the channel from IntelSat. Can I share dishes (I currently have 2 for Dish Network)? Or do I need an extra dish with its own cable into an FTA receiver (basically a completely parallel system)? What should I get? Any recommendations?
Any information appreciated!
Thx,
Chris.
Satellite: Intelsat Americas 5
Transponder: 11
Polarisation: vertical
Frequency: 11.929 GHz Ku-band
Symbol rate: 22.000
FEC: ¾
Head over to the FTA Forums (a few links below the Dish Network forum on the main page) You will need at least a 30" dish + KU LNBF to receive that paticular internatinoal channel FTA, You will also need a receiver such as a Pansat.. etc.. If you go to the FTA Forums here on Satellite Guys, the fine helpful folks can point you in the right direction.
looks like the OP needs his BVN :)
you will need a complete system for it. they aren't interchangable
You can get a system (receiver, 30" dish and LNB) for under a couple hundred (maybe 150) and theres no extra charges (and there is one helluva bunch of ethnic channels on IA5) :)
Come on over to the FTA section...we'll treat ya well :D
Thanks!
Thanks guys for the lightning fast response! Amazing!
I've started a new thread on the FTA forum.
Chris.
1.8 Meter Patriot offset dish
Comcast rates increase again
