Dish Network HD dish w/ Bell 6400 HD receivers | SatelliteGuys.US
darkfox
Sask
I'm fairly sure I've got the answer, but I'd like to make sure.
If I have a Dish Network HD dish kit (3 eye lnb) and only hook up the 110/119 outputs into a sw44 switch (and aim it at 82/91 sats), I should be able to run a coax to 4 rooms for Bell 6400 HD receivers and be good......right? lol
I agree, it sounds like that Dish, Dish will be DP or DPP LNBF's so the DPP44 is the way to go.
To avoid problems just grab a Bell or Telus Dish and a DPP Quad LNBF, then you can feed 4 x 6400's without a switch.
