Dish Network Iphone App- How To | SatelliteGuys.US
muscy
3
Hi there-
I downloaded the DNA and was wondering...care you able to actually view tv shows & dvr recordings- or is this just a remote control (that is quite funny messing w/ ppl while they are trying to watch shows). Anyways- I thought you could, but under my dvr recordings- it only allows me to play back on my tv, same as browsing for shows- I can only set up my dvr. to record or change the channel to them.
Thanks for any input (well positive would be nice) :~)
Veneicia
Yes, you can view live TV/recordings on your phone. You do need to have a 722/722k with sling adapter, or a 922 in order to do so. Without having one of these, you can only manage your DVR
http://www.dishnetwork.com/tveverywhere/default.aspx
Hi there-
Veneicia
SatelliteGuys First Look Review - DISH Sling Adapter
Pixellation on 118 with a dish 1000 plus 110/118.7/119/129
