Latitude: 52.1293°
Longitude: -106.6703°
Saskatoon, SK
Looking to get Western Arc. Can somebody point me to the coverage maps and the spot beam maps for Montana or North Dakota near the Canadian border? Thanks!
Latitude: 52.1293°
Saskatoon, SK
The WA satellites are 110/119/129. Select a satellite and click on a beam/spotbeam. If you click on the Conus Beam you'll get a map of the coverage. Same if you click on a spotbeam number.
Edit: If that's ToonTown you will probably need a larger dish for each satellite. Can't you get most everything with Rogers or Bell satellite?
Thanks Laddyboy. That is exactly what I was looking for.
If Toon Town is Saskatoon, you are correct. Bell has a weak selection of HD and what they have is overcompressed and down-rezzed. I don't think Rogers is available there.
Just a note to say that it is my experience that these footprint maps should only be considered as a rough guide. For example, I live within the green lines but need a 30inch dish to get a good signal from the conus transponders of 119.
Latitude: 52.1293°
Saskatoon, SK
