Dish network remote to Polaroid DRA 01601A DVD-Recorder, what is the code? | SatelliteGuys.US
phuddy_d
4
Ontario
I have a Dish IR/UHF Pro remote model 6.4. I want to program it to operate a Polaroid 01601A DVD recorder. Does anyone know the code? It is not 385 as reported on one site. Thanks.
Some DVR Players are not coded, many Recorders are not coded, likely all DVD-VDR player or recorder combos are not coded.
Remember they will only respond to IR signals. Of course, Dish only outputs IR on other than on the Sat setting, where it does RF only.
-Ken
Also try the Philips codes. But there's no reason the polaroid codes wouldn't be learnable. What is your learning procedure exactly?
I followed the instructions on this site for a 2-way Dish remote, published 12/19/2008. I tried both the hybrid mode and the normal mode. My other device remotes can teach the learning remote, but I have no success with the Polaroid. I tried both the VCR mode and the AUX mode on the 21.0.
The $15 RCA RCRP05B will control Dish using SAT code 0775 and your Polaroid using DVD code 0874 and the individual function codes below:
Code:
0    001231    00247
2    00250
3    00229
4    00118
5    00251
6    00100
7    00119
8    00122
9    00101
vol up    00037
vol down    00164
channel up    00055
channel down    00182
power    00246
info    00117
menu    00106
up arrow    00187
down arrow    00230
left arrow    00183
right arrow    00165
select    00234
play    00186
pause    00058
rewind    00233
fast fwd    00231
stop    00059
record    00054
exit    00116
eject    00228
add/clear    00105
analog    00053
angle    00042
audio    00040
next track    00245
prev track    00235
digitaltv    00180
discoperation    00043
dvd    00168
edit    00039
file    00170
hdd    00166
i/p    00103
inputnext    00244
setup    00232
subtitle    00038
timer    00041
timeshift    00052
title    00102
zoom    00107
Still can't think of any reason the learns would fail. The polariod uses the most common protocol there is: NEC1, Device 0, so there's nothing unusual or complex about the signals. Maybe your learning memory is already full.
mdavej, Thanks for the codes. How do I program these into a Dish 21.0 remote? Can I clear the existing memory for DVD and AUX modes to make more space? I am a newbie and have not been able to program the Dish remote to the Polaroid Power/ON/OFF button so I can't get past the first step.
Sorry for the confusion. Those codes only work with the RCA remote (or other one-for-all) I posted. There is no solution for your Dish remote besides learning, which isn't working for you. It was suggested that only a philips remote would work. I was pointing out that other remotes will also work, offering a complete solution with codes for all your devices and every function of your Poloariod recorder. Harmony remotes will also work but are much more expensive.
I don't know how to clear the learning memory in the Dish remote. Have you tried these AUX codes: 1521 1548 1906 1910?
Problem
NFL Redzone
