Dish Now Green Dot and 2 Receivers | SatelliteGuys.US
Tvland1
609
679
ohio
I recently got 2 DishNow receivers I want to use for camping and have read most the info here about them i could find but have one question.
Does anyone know If you can use 1 Green-dot money pack to activate 2 receivers or will I have to buy 2 money packs??
yes you can do this, you can use a green dot money pack pin on more than one prepaid dishnow receiver so long as you have enough funds on the money pack. For example, you could use the same money pack pin that has $20 on it to buy one day of hbo on one receiver# and then call back enter a different receiver# and use your moneypak pin to buy one day of showtime on another receiver, then you would have like $18 left. The most important thing is when you add programming and the prompt asks you if you want to use the entire amount of the moneypak you need to say NO and then go on to select how many days you want for now. Otherwise saying yes will redeem the entire amount on one receiver.
Ask green dot or DISH
Haha, seriously pretty much 99% of the reps don't even know a thing about prepaid. They will keep asking you for an account which obviously you don't have. In addition the prepaid line always sends you to the Spanish customer care.
r10fret is correct, you're good to go.
Finally got 6.18 - faster downloads and 1080p
trouble with 612
