Dish pointing | SatelliteGuys.US
Dish pointing
hdtvdeprived
33
Using the 18X20 dish Triple LNB Quad which port do you use and which satellite do you point to for best results? thanks.
Use any 'port' (coax line from dish), (any) one goes to each tuner you want to drive, if using a multiswitch (for more than 4 tuners) for example to drive 8 tuners, you put all four from the dish into the 4 end of a 4x8 multiswitch, then each of the 8 outs can goto a tuner, as for aiming, use the 101 first, assuming you have your tilt right, the other 2 should fall right in.
HDTV owners desperate??
Pixellation of DC HD Locals
