Dish Pro 500 | SatelliteGuys.US
Dish Pro 500
pec
2
Oregon
We have a DP 500 dual LNB and a 625 receiver, will this set up work as is? We have one cable from the 119 side of the dish to the separator on the receiver that goes to the sat input one and two.
We can get 119 and 110 but not at the same time. Do we need a different LNB?
you could just run a 2nd line and be done with it
If you do go with the DPPTwin route, you also need a DishPro SEPARATOR so you can run one line from the LNB to both inputs on the receiver. This isnt a regular splitter. Its a Dish specific product
OP said he already had the seperator.
myself I would run the second line........
Dish DVR 622 files to PC for editing
Dish Network made the top 50 WORST place to work list!!!
