Dish Pro Switch? | SatelliteGuys.US
Dish Pro Switch?
tacid_blue
7
Pittsburgh
I have a dual 119,110 dish pro lnb with 61.5 fed into the lnb port. I would like to add 129 to my set up with another single dish pro lnb so can i combine 129 and 61.5 with a switch and feed it into the lnb port on my dual lnb? If so what switch would I need?
You could also get a Dish 1000.4 dish which would allow you to pickup 110, 119, 129 with the built in eyes and has an extra port to connect a fourth dish. This is how I have my setup.
Just a correction on the dish, it's a 1000.2 (119, 110, 129) but other than that great idea and it might be cheaper.
tacid_blue said:
my regional sports net is on 61.5 and my hd locals are on 129.
1000.2 tripple lnb with 61.5 wind dish ( single or dual) cable ran into lnb in port on the 1000.2 lnb. Probably cheaper than switching over to everything you need for a 44.
never run dpp into a swich, if it works it will fail eventually.
Switch TV2 to a different room..
Hindi Channel 'Sanskar' and other mysteries
