Dish question (SimpleSimon)... | SatelliteGuys.US
YardApe
7
Thanks for your dish link... looks like the 105 is needed for my local channels... what did you mean by a "new" 105 dish coming out? Is there a "gotcha" to look out for?
Also, the install is using exisiting D* installation... but your grounding comment was very helpful... thanks again...
I see you have the 921 DVR... you like it?
there's a new 105 satellite, that's more powerful launching, but the dish will be the same
yeah - I like my 921 - but I don't use the OTA tuner - that seems to be where most of the problems are, although it looks like they're being fixed as time goes on.
I've got a lot of beefs about less important issues with it - but it's functional.
As for 105 - you're gonna be needing a SuperDish. :(
In closing, why'd you start a new thread instead of staying in the old one?
Just cancelled Direct TV and maybe moving
811 replacement
