Dish Re-alignment | SatelliteGuys.US
Dish Re-alignment
joeh
104
Louisville, KY Aera
Hey guys, I posted a few days back that I was having some problems picking up my locals off of 110 see post(http://www.satelliteguys.us/showthread.php?t=69549), and thought it was just my receivers, because after I reset them it was working again, but today's weather is clear sky sunny and bright, but 110 on all receivers keeps going in and out. So it is looking like my dish is slightly out of alignment. So my question is, since i have a dish that is not grounded properly, doesn't have a weathershield over connectors out side and so forth,
See this post(http://www.satelliteguys.us/showthread.php?t=58377) would I be better off to call dish and have them send out a Rep from dish itself and not a local contractor? and also does anyone know how much dish will charge for a re-alignment?
Standard service call rate for DISH is $99.00 or if you sign up for DHPP at $5.99/Mo. the service call is reduced to $29.99.:)
thanks for your repsonce. I feel like my system was never put in at top quality and I'm now starting to see the effects of the lack of quality in work. As I know the dish was never fully peaked out, the installer just just turned the dish until he got a usable signal on both 110/119.
Program archiving: offload files from USB drive to my terabyte server?
Coax Grounding question -- Help!
