dish realignment | SatelliteGuys.US
dish realignment
honestly when the signal on all sats isnt what it should be
101/110/119 (if you have 110/119) should be 90+ on all transponders (non spotbeam) (my lowest is 94)
99 & 103 should be at least 85...but usually closer to 90
you can check in the menus
thank, the reason i ask is i still getting under water sound and my CBS is mess up today but my are - 1-8 97-98-96-95-100-96-100 9-16 95-97-95-95-100-92-100 17-24 93-80-91-97-88-100-92-100 25-32 95-0-90-100-91-100-95-100
Those numbers are very good, What Satellite is it ?
I'll guess the 101, hows the 99 and 103 look ?
99C 1-8 95-89-88-85-92-88-85-85 9-16 91-89-83-85-93-98 rest are N/A 99S 1-8 57-98-0-68-0-94-N/A-N/A 9-16 ALL N/A 17-24 95-88-0-0-56-34-0-0 25-32 ALL N/A 103S 1-8 25-0-15-0-0-0-N/A-N/A 9-16 N/A-N/A-N/A-N/A-N/A-73 17-24 89 82-0-86-89-74-69 25-32 ALL N/A
not having any sound issues on CBS here on my end. can you give us some additional details?
1. Have you tested if the OTA version also has the issue?
2. How is your audio input and output?
3. Is this the only channel with this issue? If so, that itself can be very telling.
not having any sound issues on CBS here on my end. can you give us some additional details? 1. Have you tested if the OTA version also has the issue? 2. How is your audio input and output? 3. Is this the only channel with this issue? If so, that itself can be very telling.
it Erie, CBS the sound issue, its happen on many channels not all, that why i keep telling it must be a D problem, and when it happen it last 30-45 sec and go back, i have it hook up to small Home Theater Systems but, it still happen if i small Home Theater Systems off, sorry i don't what OTA version is
Sorry I can't make some of that out... So what other channels then; any? As I am not having any audio issues on the 7 - 10 channels I have watched since about 4:45am this morning; nor any at all this week. Give everyone details so they can know hoe to help and research with you.
OTA=over the air...Can you pick up the channel with an antenna to see if its something on the station
channels like HBOW, EPSNNEWS, NHLN its really weird
I can tell you 110% for sure on all of those I have no audio issues. Called 4 other to try them and nothing there either. Makes it doubtful its just DirecTV.
then oh well i don't what the issue is then, i not that techie lol
Seeing Red!
Frozen screen
