Dish remote 6.0 (#2) with receiver 510 | SatelliteGuys.US
khichadi
13
I don't know much about different model # of the dish remote controller. I have 510 receiver and few of the buttons are not working. I just bought following....
Dish Network IR 6.0 Remote Control. This is a #2 remote. This remote is designed to operate DISH Network's earlier model receivers: 301, 311, 322, 522, 625, 942, 1000, 2700, 2800, 3700, 3100, 3700, 3800, 3900, 4700, 4900 and many more. Four-function remote control. Will operate up to four devices: satellite receiver, TV, VCR, sound system, etc. Emits IR and UHF frequency.
did I make a mistake? Will it work with my dish DVR 510? Do I need special key/instruction?
i think if you have the #2 remote then at the bottom of the remote there is a #2 at the bottom, you should be able to pull it out and flip it over and put it back in . and then it should work.. but anyone can correct me if i'm wrong
That's right. The 510 won't work with the blue UHF key, but will work with the green IR key. You might have to reset the remote address if it was ever changed before.
Locals in HD?
Voom hd movies coming may 1st
