Dish Removal - Roof Install | SatelliteGuys.US
scotc
9
So the installer just mounted my dish to the roof and I don't think that is going to fly with the landlord :mad:
Does anyone have any advice for removing this and patching things up?
I'd like to reinstall on my eave right next to where it is currently installed or the wall right below the eave. Any reason not to relocate it there?
I take it you were not there when the install was scheduled.
You can remove the dish and place it wherever you would have liked the 1st time.
Make sure to get roof cement to patch up the holes. be thorough
If possible do this before the landlord knows the dish was placed there.
Jimbo
D* Autobilling question
Buying used receivers
