Dish Roof Mount Question? | SatelliteGuys.US
charlesrshell
SatelliteGuys Crazy
11,247
5,979
O'Fallon, IL
How do installers mount the dish on roofs? Do they try to bolt it down to the roof rafter or stud or whatever it is called or do they just bolt it down any place?
An experienced installer will use find the stud and at least drilled one side or the middle into stud, seal with black asphalt, I know lots installer use clear stuff but its not going to last long. The worst installer will never considering sealing as well. WE has lots these jerks around.
[COMCAST] Networking Moto 6412?
Verizon FIOS being installed in Largo, FL (maybe):
