dish router ontop of customers router question | SatelliteGuys.US
jackflash
25
north
Any techs out there try hooking a customers router to one of are routers for connectivity? I lot of times customers dont know or dont wont to tell you there wifi password and you cant use a slinglink. Not that i blame the customer but when supervisors are saying you cant leave until I get connectivity then last resort is putting are router on-top of there's or replacing there's with ares. Any suggestions out there.
Suggestion learn the difference between OUR and ARE
towboy123 said:
Most likely not going to work as it will create a Double NAT situation.
I agree.
Shouldn't it be established before beginning the install that access to the customers router including wifi password is required?
Ross
Sent from my rooted DROID RAZR Maxx using SatelliteGuys
Just wondering why you don't join the installer zone buddy? If you are infact a tech.
Hopper crashing or slowing down when downloading ON DEMAND
Hopper dvr playback issues
