Dish setup for HD in New Hampshire | SatelliteGuys.US
tony69nh
4
What dish and LNBFs are needed to get the HD channels in southern NH?
Will a Dish 1000+ with 110/118.7/119/129 work? Not sure if I would be able to get 129 in this area. Thanks in advance. Tony
Ok. what would be better then. a DIsh 500+ with 110/118.7/119? and a second dish for 61.5? or a Superdish with 110/119/121 and a second dish for 61.5?
I was thinking of the Superdish so that I could get 121 which has international channels and the Providence local channels which I am originally from in addition to 110 and 119. Or the dish500+ so that I could get 118.7 which has international channels.
I've also read from the posts here that since the dishes are bigger, the signal reception is better.
You don't think either one of those is worth getting and that I should just go with a DIsh 500 at 110/119?
I do not know anything about the Superdish or what you can get with it.
But for standard HD (119-110-61.5) use a Dish 500 w/DishPro Plus Twin LNBF - 119 & 110. A second Dish 500 w/DishPro Dual LNBF & an I bracket for 61.5.
Go to the DishStore site and look around.
recorded programs order
I am confused
