DISH TV2 & PC Connect | SatelliteGuys.US
mpinelli
2
Hi There --- new mwmbwe neding help.
Installed Dish TV & want to make PC TV 2. Have newer Dell, dual-core , tv ready w/dvr and coaxial connect. Cannot get media center to display -- tells me "the decoder is in use by another application."
Dish tech support useless;Dish installers less than useless; Dell worked hard, but couldn't get it. Any ideas? Thanks.
mpinelli
mpinelli
You got a problem with the computer so the Dell support is the one to help you.
The problem you going to have with DishTV2 is you cannot control it from IR.
I googled your error and saw where somebody said they installed an update and it fixed it. They didn't say what update it was though. Here is a link to what I found.
Media Center: Video decoder is in use by another application... - microsoft.public.windowsmedia | Google Groups
I think I would do a Windows update and also check on the Dell support website for any driver updates. Maybe you can join that forum and send the person a message and see what they updated. It looks like it is a fairly recent thread.
No, I cannot set the channel. The control on the media center display will only let me adjust the volume, so i don't have any idea on what channel the receiver is set. The pc receiver is standard for Windows XP
i would move the reciever into the room with the pc, as already mentioned even when you get a picture, you arent going to be able to control it through the computer since the tv2 side uses a uhf remote
DISHOnline w/VIP-722 Sometimes Freezes
