Anyone else having 622 issues?
I've only been a Dish customer since Monday 2/27 and I've had a working system probably about 20% of that time.
Setup:
Brand new Philips Plasma 42PF9630A
Dish 1000
VIP622 connected via HDMI
Timeline:
1. Dish 1000 installed 2/27 w/ VIP622 receiver. Technician can't get signal because, as it turns out, he hadn't installed the dish at a level plane. Everything seems to be working fine when he *finally* leaves the house.
2. Later that night, TV screen goes completely black while I'm trying to show off the new HD programming to my wife. I run some RCA cables (all I had) from receiver to TV and the picture returns. My thinking at that point is that something is wrong w/ either the HDMI cable, HDMI input on TV, or HDMI output on receiver.
3. I try a brand new receiver on Tuesday (received via UPS for original install date -- long story). At least this gives me the opportunity to troubleshoot the receiver. Yes! My picture returns via HDMI cable w/new receiver. I assume that the problem was with the old receiver, so I go ahead and have the new receiver activated via tech support. Everything functions properly for the next 20 hours.
4. Return home from work to find error message on power up. "A problem has been detected with your switch box configuration. If both tuners are being used, they must both be connected to the same satellite… faulty switch box... etc." Note that no settings of any kind have been changed since the TV was working perfectly the night before. I get on the line with tech support again. We run a couple of tests, including unscrewing the SAT 1 and SAT 2 splitter and going directly into the receiver. NO SATELLITE SIGNAL at all! They ho-hum and schedule me for a technician visit on Monday (there goes my Oscar party).
Tech support guy seems to think there's a problem with the cable running from the dish to the receiver. I'm not technical enough to understand his logic, but needless to say I'm royally bummed.
Could this be an issue of the 622's going out before they've been properly field tested? The thing works great when it works -- which so far is not very much at all.
My wife thinks I've made a HUGE mistake canceling our cable.
AAAAAaaaaaaaaaaarghhhhhhhhh!!!!
Setup:
Dish 1000
Timeline:
