Dish - Wally & Winegard Playmaker Issue | SatelliteGuys.US
TexasRanger7
6
Georgia
Hey Satellite Guys,
I could really use your help. I spent about 6 1/2 hours today with no success.
I purchased Dish's Wally & Winegard Playmaker to use the Pay As You Go option for my hunting cabin.
I did everything according to the installation guide but the have the following issue.
The Check Switch Status Progress 058 screen will run showing a progress bar at about 30%. (It doesn't say 30%, I'm estimating) I reran the scan several times but no further progress than 30%.
I decided to move the Playmaker outside thinking that some trees could be blocking the view of the southern sky. (I used the compass on my phone to make sure I was in the correct direction.)
I re-scaned and the Check Switch Status Progress 058 screen ran at about 75%.
I moved the Playmaker again to on top of my truck thinking getting it up higher would help. It did and I did the scan again and the Check Switch Status Progress 058 screen ran at 100%. However, it didn't give me the next step. It keeps going back to select state and scan options.
I am wondering what I should do. Should I make a stand to get the Playmaker 6' or 8' up in the air?
I need some expert advice.
I uploaded them to my Google Photos to view. https://goo.gl/photos/RXzqyhfFLVRnEFFd6
Premature download
DVR alert: Expedition Unknown
