Dishnetwork 322 receiver will not download guide | SatelliteGuys.US
brothersunited
4
miami
i have a cardless dishnetwork receiver 322 dual tuner model
i am getting good signal all the process run smoothly
but i keep gettin attn 129 receiver not authorized
i have called dish many times and they said the have sent hit but the receiver will not down load guide
Help pleae
A 322 should have a purple smart card. Otherwise it will have an old smart card number that won't work anymore. Have CSR or Dirt team member send you a new smart card.
Didn't Dish as if smart card was in the slot or did you tell them there wasn't one? Maybe you gave them the number that shows on the screen and they didn't ask. Receiver needs a physical smart card that is married to the receiver in order to work.
but i thought these newer receivers do not need a physical smart card to work?
they didnt ask me about a physical smart card
Trade Stocks on your satellite receiver?
