DishNetwork 622 and Media Center | SatelliteGuys.US
hugh404
I previously controlled a Dishnetwork 322 reciever with Media Center and had no problems with IR commands from Media Center IR interface. Upgraded to VIP622. Does anyone know if Media Center Rollup 2 will work with the 622 reciever? I have the 622 reciever IR set on remote channel 1. Media Center successfully learns the commands from the Dishnetwork IR remote, but when Media Center sends IR commands to 622 reciever there is no response. Using an IR blaster to get signal to reciever which is in a different room.
Dishnetwork IR remote works fine with IR blaster, so it is not signal strength problem. Any suggestions would be appreciated!
When I moved from a 301 to a 622 the same signal set worked on both. This was with a TiVo Series 2. Make sure your blaster hasn't died.
Just make sure you aren't trying to control tuner 2. That is RF only and will not work with that IR blaster. Tuner 1 should work the same as your 322 with no changes as long as it is set to remote code 01 which is the default.
External HD question
Right Angle Compression Connectors.
