DishNetwork Uplink Activity Report - 2/27/2008 12:00pm - 52 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 03/01/2008 - 52 changes
Uplink Comparison Range: 02/27/2008 11:05A - 02/27/2008 12:00P -
127 - OXYGN - EchoStar7 119W TP 17 ConUS beam changed flags from 0101027C00FDFF to 0101027C00FCFF
128 - WE - EchoStar7 119W TP 12 ConUS beam changed flags from 0101026300FCFF to 0101026300FDFF
130 - AMC - EchoStar7 119W TP 08 ConUS beam changed flags from 0101028B00FDFF to 0101028B00FCFF
131 - IFC - EchoStar7 119W TP 06 ConUS beam changed flags from 0101026D00FDFF to 0101026D00FCFF
152 - CSTV - EchoStar8 110W TP 05 ConUS beam changed flags from 0101028600FCFF to 0101028600FDFF
158 - FUSE - EchoStar7 119W TP 02 ConUS beam changed flags from 0101026500FDFF to 0101026500FCFF
184 - ANIML - EchoStar7 119W TP 02 ConUS beam changed flags from 0101027600FCFF to 0101027600FDFF
185 - HLMRK - EchoStar8 110W TP 11 ConUS beam changed flags from 0101028000FDFF to 0101028000FCFF
225 - TJC [MPEG2 SD] added to EchoStar8 110W TP 10 ConUS beam (Not Available)
421 - CSTNO [MPEG2 SD] added to EchoStar10 110W TP 23 Spotbeam 12(LA) (Not Available)
574 - FPCHN (A) removed from EchoStar1 148W TP 09 ConUS beam
574 - FPCHN (A) removed from EchoStar3 61.5W TP 08 ConUS beam
575 - FPCHN moved from EchoStar1 148W TP 09 ConUS beam to EchoStar1 148W TP 29 ConUS beam (A)
575 - FPCHN moved from EchoStar3 61.5W TP 12 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
576 - ZEESA - EchoStar7 119W TP 21 ConUS beam changed flags from 0101016300FDFF to 0101016300FCFF
576 - ZEESA - EchoStar3 61.5W TP 12 ConUS beam changed flags from 0101016300FDFF to 0101016300FCFF
601 - RAI (A) removed from EchoStar1 148W TP 07 ConUS beam
601 - RAI (A) removed from EchoStar3 61.5W TP 14 ConUS beam
653 - ARANG (A) removed from EchoStar1 148W TP 07 ConUS beam
653 - ARANG (A) removed from EchoStar3 61.5W TP 14 ConUS beam
681 - CCTV4 moved from EchoStar9 121W TP 29 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
684 - ETNEW moved from EchoStar9 121W TP 22 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
724 - GKINO - Anik F3 118.7W TP 19 ConUS beam changed flags from 01011B6F00FDFF to 01011B6F00FCFF
730 - LEOWD - Anik F3 118.7W TP 28 ConUS beam changed flags from 0101005800FDFF to 0101005800FCFF
752 - EURCH [MPEG2 SD] added to Anik F3 118.7W TP 07 ConUS beam (Not Available)
763 - NILE moved from EchoStar9 121W TP 22 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
765 - DUBAI moved from EchoStar9 121W TP 22 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
768 - ABUDA moved from EchoStar9 121W TP 15 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
902 - GEONW moved from EchoStar3 61.5W TP 32 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
903 - AAGTV moved from EchoStar3 61.5W TP 32 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
5700 - CCTV4 [MPEG2 SD] added to EchoStar9 121W TP 29 ConUS beam (Available)
5720 - ETNEW [MPEG2 SD] added to EchoStar9 121W TP 22 ConUS beam (Available)
5728 - RAI EchoStar2 148W TP 24 ConUS beam MPEG2 SD changed to DUBAI - EchoStar9 121W TP 22 ConUS beam MPEG2 SD
5728 - RAI (A) removed from EchoStar3 61.5W TP 08 ConUS beam
5729 - ARANG EchoStar2 148W TP 26 ConUS beam MPEG2 SD changed to ABUDA - EchoStar9 121W TP 15 ConUS beam MPEG2 SD
5729 - ARANG (A) removed from Echostar12 61.5W TP 23 ConUS beam
5739 - NORST [MPEG2 SD] added to EchoStar9 121W TP 13 ConUS beam (Available)
5745 - NILE [MPEG2 SD] added to EchoStar9 121W TP 22 ConUS beam (Available)
5960 - XWJET (A) removed from EchoStar9 121W TP 14 ConUS beam
5961 - XWSEE (A) removed from EchoStar9 121W TP 14 ConUS beam
5965 - XWAOW (A) removed from EchoStar9 121W TP 09 ConUS beam
5966 - XWSAW (A) removed from EchoStar9 121W TP 09 ConUS beam
5969 - XKSWO (A) removed from EchoStar9 121W TP 09 ConUS beam
5970 - XKAUZ (A) removed from EchoStar9 121W TP 09 ConUS beam
5974 - XWLNE (A) removed from EchoStar9 121W TP 14 ConUS beam
5975 - XWPRI (A) removed from EchoStar9 121W TP 14 ConUS beam
5978 - XWDTN [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
5979 - XWHIO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
5980 - XWSYX [MPEG2 SD] added to AMC-15 105W TP 18 ConUS beam (Available)
5981 - XWBNS [MPEG2 SD] added to AMC-15 105W TP 18 ConUS beam (Available)
7200 - WSYX moved from AMC-15 105W TP 18 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)
7201 - WBNS moved from AMC-15 105W TP 18 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)
Channels in the system: 4685
(A) = Available to subscribers
(NA) = Not Available
interesting...Comcast Sports New orleans but only a spotbeam?????
So its going to be like FSNW2 a while back and only available to the local area
But then again, CST has a retrans dispute with one of the big cable companies in LA so this may help Dish get more subs
CSTNO is not Comcast but Cox, there has been an ongoing controversy between Charter Communications who covers the north shore of Lake Ponchatrain and Cox who produces and broadcasts the Hornets basketball games via cable with carrying the games, Charter is refusing to pay what Cox wants to charge and Cox has threatened to bring the games to Direct and Dish, looks like they are making their threat good, but until it is turned on it may only be a bluff,
Bob
WBNS moved from AMC-15 105W TP 18 ConUS beam to AMC-15 105W TP 02 ConUS beam (A) ???
Is this channel on 129 also ?
What do those mean ? Specifically the "X" in the call letters... They're supposed to be moving these channels off of 129'.
Actually no, they aren't moving off of 129. They are moving off of 105. If I remember right, the real channel is moved to the X... channel name/number. The original channel number is moved to a slate telling customers their channel is gone. If the customer calls up and freaks out on the CSR then they tell them to tune to the X ones. Kind of like their last chance before they are gone.
yes
The locals on 121 & 105 have been on 129 for a while. Dish is finally removing them off 105 & 121 but some people may not have a 129 dish yet. So they have the slates saying the channels are moving and to call Dish for a dish upgrade.
D
DishNetwork Uplink Activity Report - 2/27/2008 12:55pm - 1 change
D
DishNetwork Uplink Activity Report - 2/27/2008 2:45pm - 50 changes
