DishNetwork Uplink Activity Report - 3/5/2008 4:20pm - 42 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 03/08/2008 - 42 changes
Uplink Comparison Range: 03/05/2008 01:05P - 03/05/2008 04:20P -
679 - PHNIN moved from EchoStar9 121W TP 15 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
680 - PHNIX moved from EchoStar9 121W TP 29 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
682 - ETDRA moved from EchoStar9 121W TP 22 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
683 - ETGLB moved from EchoStar9 121W TP 22 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
685 - ETCHI moved from EchoStar9 121W TP 16 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
687 - YOYO moved from EchoStar9 121W TP 22 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
688 - JET moved from EchoStar9 121W TP 29 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
690 - CTV moved from EchoStar9 121W TP 15 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
693 - SKLNK moved from EchoStar9 121W TP 16 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
708 - HUNAN moved from EchoStar9 121W TP 17 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
759 - ARTMV (A) removed from EchoStar9 121W TP 13 ConUS beam
760 - LBC (A) removed from EchoStar9 121W TP 13 ConUS beam
762 - ESC-1 (A) removed from EchoStar9 121W TP 13 ConUS beam
772 - ALARA (A) removed from EchoStar9 121W TP 13 ConUS beam
787 - ZEETV (A) removed from EchoStar9 121W TP 13 ConUS beam
788 - TVASA (A) removed from EchoStar9 121W TP 13 ConUS beam
789 - SET (A) removed from EchoStar9 121W TP 13 ConUS beam
790 - ZCINE (A) removed from EchoStar9 121W TP 13 ConUS beam
791 - B4U (A) removed from EchoStar9 121W TP 13 ConUS beam
794 - AAJTK (A) removed from EchoStar9 121W TP 13 ConUS beam
5701 - ARTMV EchoStar9 121W TP 29 ConUS beam MPEG2 SD changed to CTV - EchoStar9 121W TP 15 ConUS beam MPEG2 SD
5702 - LBC EchoStar9 121W TP 29 ConUS beam MPEG2 SD changed to SKLNK - EchoStar9 121W TP 16 ConUS beam MPEG2 SD
5708 - CTS EchoStar9 121W TP 15 ConUS beam MPEG2 SD changed to PHNIX - EchoStar9 121W TP 29 ConUS beam MPEG2 SD
5709 - ART EchoStar9 121W TP 29 ConUS beam MPEG2 SD changed to ETGLB - EchoStar9 121W TP 22 ConUS beam MPEG2 SD
5712 - B4U EchoStar9 121W TP 29 ConUS beam MPEG2 SD changed to HUNAN - EchoStar9 121W TP 17 ConUS beam MPEG2 SD
5714 - ICBLE (A) removed from EchoStar9 121W TP 29 ConUS beam
5717 - ESC-1 (A) removed from EchoStar9 121W TP 22 ConUS beam
5722 - SHARA (A) removed from EchoStar9 121W TP 18 ConUS beam
5723 - TVASA (A) removed from EchoStar9 121W TP 15 ConUS beam
5725 - ALARA (A) removed from EchoStar9 121W TP 29 ConUS beam
5975 - XWPRI [MPEG2 SD] - EchoStar3 61.5W TP 16 ConUS beam changed to Available
7771 - WPRI EchoStar3 61.5W TP 16 ConUS beam changed from MPEG2 SD to (0X92) (A)
7775 - WLWC EchoStar3 61.5W TP 16 ConUS beam changed from MPEG2 SD to (0X92) (A)
7776 - WSBE EchoStar3 61.5W TP 16 ConUS beam changed from MPEG2 SD to (0X92) (A)
Channels in the system: 4731
(A) = Available to subscribers
(NA) = Not Available
What does that 0x92 mean to the Providence, RI stations?
I just got this in about the Providence Stations.
Effective March 5, the following local channels in the Providence, RI DMA
will not be viewable on non 8PSK equipment (301, 501, 508, 510, 721, 2800,
3900, 4900, 2000, 1000, 1500, 3000, 3500, 3700, 3800, 4000, 4500, 4700,
5000, and 5500).
Customers impacted will see a black screen with a banner.
As part of the free 8PSK receiver upgrade project these receiver models need
to be upgraded to 8PSK capable receivers in order to continue receiving
local programming. Non-local programming will not be impacted by this
service change.
WPRI 7771
WLWC 7775
WSBE 7776
I mentioned this last week in the Pub Members area.
D
DishNetwork Uplink Activity Report - 3/5/2008 1:05pm - 12 changes
D
DishNetwork Uplink Activity Report - 3/5/2008 12:40pm - 48 changes
