Dishonline - Music Channels | SatelliteGuys.US
llokey
206
253
I cannot see any of the music channels on my DVR when using dishonline. I know they were there in the past. Has something changed or is it just the normal set of problems that exist with the dishonline service?
As some additional information surfaces, I can connect to the DVR and see what is recording. However dishonline says my DVR is not connected. Seems to be a conflict somewhere. Guess I will reboot the box when the present recording is over and see what happens. Thinks it's possible to reboot dishonline?:)
The Sirus channels are not showing up on my dishonline either. They show up on my dish remote access, but when I play them, I get music for about a second, then silence and a message there is no video stream. The CD audio shows up and plays though.
I wonder if there is an issue with the Sirius/XM people not allowing the music to be streamed.
Miner
You can go to live tv through dishonline and then manually change to a sxm channel. The picture of the previous channel will freeze, but the sound will come through. Did this today.
Matt - hate to quibble but I show many things above 900 just no music.
Also finally got dishonline to see my dvr by logging into DRA. Hopefully one day dishonline will be able to reach the boot strings of DRA - hopefully before DRA goes away.
Miner
yep, this is what i do
*OK* PLEASE HELP A DUMMY RECORD ON ONE CH AND WATCH ANOTHER!
Installer coming out on Monday. what should i be checking for?
