DishPro LNB Help | SatelliteGuys.US
DishPro LNB Help
dlatin
10
I was told i wouldn't need a switch for my DishPro500 LNB, that it would be built in. I guess I don't understand, it appears to have cable from the 119 and 110 that would need to go into a switch in order to get 1 cable that goes into my receiver. Am I missing something here? I'd post a couple of pics of it but it won't let me because I don't have enough posts...
Thanks for the help.
D
maybe now?
Thats a twin lnbf that has the equivalent of sw -21 switch's built into this unit, stock this will run two receivers or a dual tuner of the following series, 21, 22, 25, and 42 not to mention one or more future release dual tuner receivers slated to come out.
Ok, I get it, that is what I was told. It was just when I looked at it I thought the outputs were for each LNB (and thus each satellite) and they needed to be combined.
Thanks!
Actually, it's NOT SW-21s, but the equivalent of a DP22 (or a pair of DP21s).
522 Sound Problems
Will CBS HD on 129 ?
