DishPro Twin LNBF | SatelliteGuys.US
DishPro Twin LNBF
Furious
6
I have an extra DishPro 500 Twin LNBF satellite thats not being used. I currently have a DP 500 Twin hooked up with the 110/119 satellites with a secondary dish with a single LNBF getting my locals on 148. What else can I do with this twin satellite if anything? Can I use it to pick up other satellites or will it only pick up the 110/119 satellites?
A D500 with Twin can be used for 61.5, 110, 119, and 148.
Note that it does NOT point the same as a Dish300. It's going to be 4.5 degrees off. Note your D500 numbers, then check D300 numbers for 110 & 119 - you'll see.
Play with whatever you want, but keep it as a spare, for sure. ;)
2.81 811 release. What are the new bugs?
Comcast & Dish reach agreement for Sacramento area
